HP Compaq nc6230 Notebook - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the hard disk drive for the HP Compaq nc6230 Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
  • Small, Phillips-head (P0 and P1) screwdrivers
  • Small, flat-bladed screwdriver or a flat-bladed alignment tool
Parts required
The replacement part number will vary depending on the hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
60GB Ultra ATA-100 enhanced IDE hard drive - 7,200 RPM, 9.5 mm form factor - Includes mounting screws
380950-001 (Original)
Yes
80GB Ultra ATA-100 enhanced IDE hard drive - 5,400 RPM, 9.5 mm form factor - Includes mounting screws
416897-001 (Original)
Yes
60GB Ultra ATA-100 enhanced IDE hard drive - 5,400 RPM, 9.5 mm form factor - Includes mounting screws
416895-001 (Original)
Yes
40GB Ultra ATA-100 enhanced IDE hard drive - 5,400 RPM, 9.5 mm form factor - Includes mounting screws
379808-001 (Original)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library,
Click here to access the technical article at: Click here to go to HP Service Media Library then select Hard disk drive from the menu on the upper left hand side of the screen.
Hard disk drive removal
  2. Loosen the two captive P0 Phillips-head screws that secure the hard disk drive cover to the bottom of the notebook.
  3. Use the finger or a flat-bladed tool to lift the inside edge of the hard disk drive cover and remove it.
  4. Loosen the captive spring-loaded P1 Phillips-head screw that secures the hard disk drive.
  5. Grasp the Mylar tab and pull the hard disk drive toward the outside edge of the base enclosure to disconnect the hard disk drive from the system board connector.
  6. Lift the hard disk drive out of the bay and remove.
  7. If present, remove the hard disk drive PIN extender. (
    This procedure is not shown in the video.
  8. Place the hard disk drive in a static dissipative bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. If required, replace the hard disk drive PIN extender. (
  3. Place the hard disk drive into the hard disk drive bay.
  4. Push the hard disk drive toward the inside of the base enclosure until the connector is seated.
  5. Tighten the captive spring-loaded P1 Phillips-head screw that secures the hard disk drive.
  6. Toe the hard disk drive cover into the enclosure.
  7. Tighten the two captive P0 Phillips-head screws.
