Replacing Cartridges for HP LaserJet M1319f Multifunction Printer
This document contains steps to check print cartridge compatibility, and to replace an old print cartridge with the new one.
TIP
If you do not have a new print cartridge on hand, you might be able to continue printing if you rock the print cartridge back and forth six to eight times to redistribute the toner. See Step two in this document for more details.
Replacing print cartridges
Follow these steps to replace a print cartridge.
Video of replacing the print cartridge
The following video demonstrates how to replace cartridges.
If you have trouble viewing the video, or to view the video in a different size, click here to play the video on YouTube.
Step one: Check print cartridge compatibility
Before unpacking a new print cartridge, make sure that it is compatible with your HP product.
Step two: Replace the print cartridge
Follow these steps to replace the print cartridge.
  1. Press the power switch to turn on the product.
  2. Press the blue tab, and then open the print cartridge door.
    Figure : Open the print cartridge door
    Illustration: Open the print cartridge door
  3. Grasp the handle on the old print cartridge, and then pull the print cartridge straight out to remove it. Seethe recycling information inside the print cartridge box.
  4. Remove the new print cartridge from its packaging.
  5. Hold the print cartridge at both ends, and then rock it back and forth six to eight times to ensure uniform printing.
    Figure : Rock the print cartridge back and forth
    Illustration: Rock the print cartridge back and forth.
  6. Remove the orange plastic shield,and then pull the orange tab straight out to remove the sealing tape.
    Figure : Remove the sealing tape
    Illustration: Remove the sealing tape.
    To prevent print quality issues, do not touch the imaging drum.
    Figure : Do not touch the imaging drum
    Illustration: Do not touch the imaging drum.
  7. Insert the print cartridge into the product until it is firmly in place.
    Figure : Insert the print cartridge
    Illustration: Insert the print cartridge.
  8. Close the print cartridge door.
    Figure : Close the print cartridge door
    Illustration: Close the print cartridge door.
