    Windows 11 Upgrade Guide
HP Compaq 8100 Elite Small Form Factor Business PC Specifications
Product image
Product features
Feature
Intel Q57 Express supporting Intel Core processor with vPro technology
Processor and Speed
Intel Pentium Processors:
  • Intel Pentium G6950 Processor 2.80-GHz, 3M total cache 2 cores/2 threads Integrated Intel HD Graphics
Intel Core i3 Processors:
  • Intel Core i3-530 Processor 2.93-GHz, 4M total cache 2 cores/4 threads Integrated Intel HD Graphics
  • Intel Core i3-540 Processor 3.06-GHz, 4M total cache 2 cores/4 threads Integrated Intel HD Graphics
Intel Core i5 Processors:
  • Intel Core i5-650 Processor 3.2-GHz, 4M total cache 2 cores/4 threads Integrated Intel HD Graphics Intel Core processor with vPro technology Intel Stable Image Platform Program (SIPP)
  • Intel Core i5-660 Processor 3.33-GHz, 4M total cache 2 cores/4 threads Integrated Intel HD Graphics Intel Core processor with vPro technology Intel Stable Image Platform Program (SIPP)
  • Intel Core i5-670 Processor 3.46-GHz, 4M total cache 2 cores/4 threads Integrated Intel HD Graphics Intel Core processor with vPro technology Intel Stable Image Platform Program (SIPP)
  • Intel Core i5-750 Processor 2.66-GHz, 8M total cache 4 cores/4 threads Requires a discrete graphics solution
  • Intel Core i5-750S (low power) Processor 2.40-GHz, 8M total cache 4 cores/4 threads Requires a discrete graphics solution
Intel Core i7 Processors:
  • Intel Core i7-860 Processor 2.80-GHz, 8M total cache 4 cores/8 threads Requires a discrete graphics solution Intel Core processor with vPro technology Intel Stable Image Platform Program (SIPP)
  • Intel Core i7-870 Processor 2.93-GHz, 8M total cache 4 cores/8 threads Requires a discrete graphics solution Intel Core processor with vPro technology Intel Stable Image Platform Program (SIPP)
Memory
  • 1 GB DDR3 SDRAM PC3-10600 (1333MHz) non ECC (1 x 1 GB)
  • 2 GB DDR3 SDRAM PC3-10600 (1333MHz) non ECC (1 x 2 GB)
  • 3 GB DDR3 SDRAM PC3-10600 (1333MHz) non ECC (1 GB + 2 GB)
  • 4 GB DDR3 SDRAM PC3-10600 (1333MHz) non ECC (1 x 4 GB)
  • 4 GB DDR3 SDRAM PC3-10600 (1333MHz) non ECC (2 x 2 GB)
  • 8 GB DDR3 SDRAM PC3-10600 (1333MHz) non ECC (2 x 4 GB)
  • 8 GB DDR3 SDRAM PC3-10600 (1333MHz) non ECC (4 x 2 GB)
  • 16 GB DDR3 SDRAM PC3-10600 (1333MHz) non ECC (4 x 4 GB)
Hard Drives
  • 160 GB Hard Disk Drive 7,200 rpm, 8 MB cache, 3.0 GB/s, 3.5 in drive
  • 160 GB Hard Disk Drive 10,000 rpm, 16 MB cache, 3.0 GB/s, 2.5 in drive (includes 3.5 in adapter)
  • 160 GB Removable Hard Disk Drive 7,200 rpm, 8 MB cache, 3.0 GB/s
  • 250 GB Hard Disk Drive 7,200 rpm, 8 MB cache, 3.0 GB/s, 3.5 in drive
  • 250 GB Removable Hard Disk Drive 7,200 rpm, 8 MB cache, 3.0 GB/s
  • 320 GB Hard Disk Drive 7,200 rpm, 8 MB cache, 3.0 GB/s, 3.5 in drive
  • 500 GB Hard Disk Drive 7,200 rpm, 16 MB cache, 3.0 GB/s, 3.5 in drive
  • 1 TB Hard Disk Drive 7,200 rpm, 16 MB cache, 3.0 GB/s, 3.5 in drive
Solid State Drives
64 GB Solid State Drive 2.5 in drive (includes 3.5 in adapter)
5.25 in Optical Drives
  • DVD-ROM Drive
  • SuperMulti LightScribe DVD Writer Drive
  • Blu-Ray Writer Drive
Media Card Readers
  • Media Card Reader (22-in-1)
  • Media Card Reader (22-in-1) with 1394 port
Network Interface Connection
  • Intel 82578 GbE Network Connection (integrated)
  • Intel Gigabit CT Desktop NIC Card
  • Broadcom NetXtreme GbE Ethernet Plus NIC (PCIe x1)
The integrated network connection is required to support the vPro Technology features.
  • HP 802.11b/g/n Wireless NIC (PCIe x1)
These wireless network interface solutions will disable the vPro Technology features.
Modem
LSI Hi-Speed 56K International Soft Modem (PCIe x1)
Keyboard/Mouse
Keyboard:
  • HP PS/2 Standard Keyboard
  • USB Standard Keyboard
  • USB SmartCard Keyboard
  • USB Mini Keyboard
  • USB & PS/2 Washable Keyboard
Mouse:
  • PS/2 Optical Scroll Mouse
  • USB Optical Scroll Mouse
  • USB Laser Scroll Mouse
Graphics
Integrated graphics with Intel Pentium processor, Intel Core i3 processors, and select Intel Core i5 processors:
  • Intel HD Graphics (integrated) on selected models
Available discrete graphics cards:
  • NVIDIA GeForce 310 DP PCIe x16 Graphics Card
  • Nvidia Quadro NVS 290 Graphics Card
  • Nvidia Quadro NVS 295 Graphics Card
  • ATI Radeon HD 4550 Graphics Card
  • ATI Radeon HD 4650 DP (1GB) PCIe x16 Graphics Card (CMT only)
  • HP ADD2 SDVO + DVI-D Video Adapter
  • HP DisplayPort to DVI-D Adapter
  • HP DisplayPort to VGA Adapter
Power Supply
  • 240 W active PFC
Security
  • IEEE and WiFi compliant 64 / 128 bit WEP encryption
  • AES: CCM
  • 802.1x authentication
  • WPA: 802.1x. WPA-PSK and TKIP
  • WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through V5
Communications
Features
Communication
  • HP Wireless 802.11 b/g/n NIC Card
  • Broadcom NetXtreme GbE Ethernet Plus NIC Card
  • LSI Hi-Speed 56K Int'l Soft Modem Card
  • RJ11 Modem Adapter Kit
Graphics
Audio/Visual
Features
Audio/Visual
  • High Definition Audio with Realtek ALC261 codec (all ports are stereo)
  • Microphone/Headphone and dedicated headphone front ports
  • Line-out and Line-In rear Ports
  • Multi-streaming capable
  • Internal Speaker (standard)
  • HP Thin USB Powered Speakers
  • HP TV Tuner (Americas) PCIe x1 Card
Physical specifications
Features
Chassis Dimensions (H x W x D)
447.8 x 177.8 x 444.5 mm (17.63 x 7.00 x 17.5 in)
System Weight
11.15 kg (24.54 lb)
Temperature
Operating: 10° to 35°C (50° to 95°F)
Non-operating: –30° to 60°C (–22° to 140°F)
Operating temperature is de-rated 1.0°C per 300 m (1000 ft) to 3000 m (10,000 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 10°C/Hr. The upper limit may be limited by the type and number of options installed.
Humidity
Operating: 10% to 90% (non-condensing at ambient)
Non-operating: 5% to 95% (non-condensing at ambient)
Altitude
Operating: 3048 m (10,000 ft)
Non-Operating: 9144 m (30,000 ft )
Software/OS
Feature
Operating System
  • Genuine Windows Vista Business
  • Genuine Windows 7 Professional Edition
  • Windows XP Professional
Warranty information
HP Services includes a one-year standard parts and labor warranty, pick-up or carry-in, and toll-free 7 x 24 hardware technical phone support. On-site service and warranty upgrades are also available.
