HP Color LaserJet CM1312 MFP Series - Options When Installing the HP Full Feature Software on Microsoft Windows 7
HP Color LaserJet CM1312 MFP Series - Options When Installing the HP Full Feature Software on Microsoft Windows 7.
Details
When performing a typical installation of the HP Full Feature Software, either by the CD auto running or by manually running setup.exe from the CD a basic installation is the default. This shortens the overall installation time for basic software functionality.
Additional software such as HP Solution Center, ToolboxFX and HP Update, etc, are not installed by default. These are available for installation from the install CD.
Installing the Additional HP Software on the CD:
The following Figure shows a typical installation and what software gets installed by default. That would be when autorunning or when clicking setup.exe on the CD.
In order to view the additional software available for installation, select Install More Product Software as shown in the Figure below.
Now select the desired additional software programs to be installed (see the Figure below).
This method is applicable to both 32 and 64-bit operating systems.
Country: Flag Serbia
