    Fix HP Printer issue on macOS
HP L185b 18.5-inch Widescreen LCD Monitor - Overview
Product description
L185b 18.5-inch Widescreen LCD Monitor offers advanced features and functionality, a superior ergonomic design, and the latest technologies for use in a variety of small-to-medium businesses as well as corporate environments.
Product features
Feature
Model
WE129AA
Type
18.5-inch Wide-Aspect Active Matrix TFT (thin film transistor)
Viewable Image Area
47 cm (18.5 in) widescreen
Screen Opening (W x H)
230.4 x 409.8 mm (9.07 x 16.13 in)
Panel Type
TN
Aspect Ratio
16:9
Viewing Angle (typical)1
Up to 170° horizontal/160° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
250 nits (cd/m2)
Contrast Ratio (typical)1
1000:1
Dynamic Contrast Ratio (typical)1
30,000:1
Response Time (typical)1
5 ms (On/Off)
Pixel Pitch
0.3 mm
Backlight Lamp Life (to half brightness)
50,000 hours
Color Gamut
72%
Tilt Range
-5° to +15°
Swivel Range
No
Height Adjustable
No
Pivot Rotation
No
Base
Attachable, ships detached
  1. All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
Links to product QuickSpecs
Information for this Overview is taken from the product QuickSpecs. To access the complete QuickSpecs for this product, select the desired link from the following list:
