When using the Automatic Document Feeder (ADF) to copy, scan, or fax, the error message 'Original Jam: Clear jam, and then press OK' displays on the product control panel.
Figure : Automatic Document Feeder (ADF)
caution:Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage theprint mechanism.
note:Thoroughly check the rollers and wheels for torn pieces of paper. If any torn pieces of paper remain inside the top cover, more jams are likely to occur.
note:Make sure to close the ADF top cover tightly at both ends. A false error message might occur if the cover is not securely closed.
note:Thoroughly check the lid for torn pieces of paper. If any torn pieces of paper remain inside the document lid, more jams are likely to occur.
note:Use a flashlight to thoroughly check the rollers for torn pieces of paper. If any torn pieces of paper remain inside the ADF mechanism, more jams are likely to occur.
note:If the product does not continue the task, start the task again.
