- ${title}
- ${title}
- ${title}
- ${title}
HP LaserJet Pro M1130 and M1210 Multifunction Printer Series - Setting Up the LaserJet (Hardware)
This document includes the following steps to set up the printer:
Check the contents of the box
Remove packing tape
Prepare the print cartridge
Prepare the output bin
Load plain paper
Connect the power cord
Turn on power
Setting up the printer
Follow these steps in order.
Step one: Check the contents of the box
Remove the printer from the box, and then check the contents of the box.
Step two: Remove packing tape
Remove all packing tape from the printer.
Step three: Prepare the print cartridge
Open the cartridge access door.Figure : Open the cartridge access door
Lift up the paper packing, but do not remove it.Figure : Lift the paper packing
Remove the print cartridge packaging.Figure : Remove the print cartridge packaging
Remove the print cartridge from the printer.Figure : Remove the print cartridge
To prevent damage to the print cartridge, hold the print cartridge at each end. -
Remove the packaging from inside the printer.Figure : Remove the packaging from inside the printer
Remove the orange clip from the end of the print cartridge.Figure : Remove the orange clip from the print cartridge
Gently rock the print cartridge back and forth to distribute the toner evenly.Figure : Rock the print cartridge
Bend the tab on the left side of the print cartridge until the tab breaks loose. Pull the tab to remove all the sealing tape from the print cartridge.Figure : Remove the sealing tape
If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric. -
Insert the print cartridge, and then close the print cartridge door.Figure : Insert the print cartridge and close the door
Step four: Prepare the output bin
Insert the output bin extender into the output bin. The two clips on either side of the extender snap into place.
Figure : Insert the output bin extender
Step five: Load plain paper
Load the paper face-up, top forward in the input tray.Figure : Load paper in the input tray
Slide the paper guides inward so that they rest against the stack of paper.
To prevent jams and skewing, always adjust the side and front paper guides.Figure : Adjust the paper guides
Step six: Connect the power cord
Connect the power cord to the back of the printer.Figure : Connect the power cord
Plug the power cord into an electrical outlet.
Step seven: Turn on power
Press the Power button (
) to turn on the printer.
Figure : Turn on the power
note:A blank page might print when you turn on the printer for the first time.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
