This document is for HP LaserJet Pro M1130 and M1210, and HotSpot M1218nfs MFP series printers.
Model
Part Number
HP LaserJet Pro M1132
CE847A
HP LaserJet Pro M1134
CE848A
HP LaserJet Pro M1136
CE849A
HP LaserJet Pro M1137
CE850A
HP LaserJet Pro M1138
CE851A
HP LaserJet Pro M1139
CE852A
HP LaserJet Pro 1212nf
CE841A
HP LaserJet Pro 1213nf
CE845A
HP LaserJet Pro 1214nfh
CE842A
HP LaserJet Pro 1216nfh
CE843A
HP LaserJet Pro 1217nfw
CE844A
HP LaserJet Pro 1219nf
CE846A
HP HotSpot LaserJet Pro 1218nfs
B4K88A
Feature
Minimum system requirements
Windows Vista, 7, 8, 10
Processor
1 GHz 32-bit (x86) or 64-bit (x64) processor
RAM
1 GB (32-bit) or 2 GB (64-bit)
Free disk space
2 GB
Browser
Internet Explorer, Firefox, Google Chrome
Windows XP
Processor
Pentium 233 MHz processor
RAM
128 MB
Free disk space
150 MB
Browser
Internet Explorer 7.0
Mac OS X v10.4, v10.5, v10.6, and Higher
Processor: PPC and Intel Core Processor Macs
RAM: 256 MB
Free disk space: 150 MB
Connectivity
M1130 Series
M1210 and HotSpot M1218nfs Series
Hi-Speed USB 2.0 port
Yes
Yes
RJ-11 fax port
N/A
Yes
RJ-11 line-out telephone port
N/A
Yes
RJ-45 network port
N/A
Yes
Specification
M1130 Series
Height
250 mm (9.8 in)
306 mm (12.0 in)
Depth
265 mm (10.4 in)
265 mm (10.4 in)
Width
415 mm (16.3 in)
435 mm (17.1 in)
7.0 kg (15.4 lb)
8.3 kg (18.3 lb)
The Americas
Europe
Middle East and Africa
Asia Pacific
Cartridge Number
HP 85A Black
HP LaserJet CE285A Black
Tray
Paper type
Paper specifications
Quantity
Input tray
Paper
60 g/m2 (16 lb) bond to 163 g/m2
(43 lb) bond
150 sheets
Envelopes
60 g/m2 (16 lb) bond to 90 g/m2
(24 lb) bond
Up to 10 envelopes
Transparencies
Minimum 0.13 mm (0.005 in)
thick
Up to 75 transparencies
Output bin
Paper
75 g/m2 (20 lb)
bond
Up to 100 sheets
Envelopes
Less than 60 g/m2 (16 lb) bond to
90 g/m2 (24 lb) bond
Up to 10 envelopes
Transparencies
thick
Automatic Document Feeder (M1210 and HotSpot M1218nfs series
only)
Paper
(24 lb) bond
Up to 35 sheets
Type
Size
Paper
Letter:216 x 279 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm (8.27 x 11.69 inches)
Executive: 184 x 267 mm (7.24 x 10.51 inches)
A5: 148 x 210 mm (5.83 x 8.27 inches)
A6: 105 x 148 mm (4.13 x 5.83 inches)
B5 (JIS): 182 x 257 mm (7.17 x 10.12 inches)
16k:
Custom:
Envelopes
#10: 105 x 241 mm (4.13 x 9.49 inches)
DL: 110 x 220 mm (4.33 x 8.66 inches)
C5: 162 x 229 mm (6.93 x 9.84 inches)
B5: 176 x 250 mm (6.7 x 9.8 inches)
Monarch: 98 x 191 mm (3.9 x 7.5 inches)
Postcards
Postcard (JIS): 100 x 148 mm (3.94 x 5.83 inches)
Double postcard (JIS): 148 x 200 mm (5.83 x 7.87 inches)
note:The Automatic Document Feeder (ADF) supports paper types that are within the following weight range: 60-90 g/m2 (16-24 lb bond).
Type
Size
Paper
Letter: 216 x 279 mm (8.5 x 11 inches)
16k:
Custom:
Specification
M1130 Series
Print Speed
Up to 19 ppm for Letter, and up to 18 ppm for A4
Resolution
600 pixels per inch (ppi) for complex graphics
300 ppi for normal graphics and text
150 ppi for photos
150 ppi for photos
Duty Cycle
Prints letter-size pages at speeds up to 19 pages per
minute (ppm) and A4-size pages at speeds up to 18 ppm.
Supports manual two-sided (duplex) printing
Yes
Yes
warning:Power requirements are based on the country/region where the product is sold. Do not convert operating voltages. Doing so might damage the product and void the product warranty.
note:Any changes or modifications to the product that are not expressly approved by Hewlett-Packard could void the user's authority to operate this equipment.
