HP Designjet L25500 Printer Series - Clean the printheads
Periodic printhead cleaning is performed automatically, as long as the printer is kept turned on. However, you should clean the printheads if you are experiencing poor image quality and cannot resolve the issues by other methods. This ensures that there is fresh ink in the nozzles and helps to prevents nozzle clogs.
If you have printed the printhead status plot, you know which colors are failing. Clean the pair of printheads that are not performing adequately. If you are not sure which printheads to clean, clean all of the printheads.
To clean the printheads, go to the printer's front panel and select the icon, select Image quality maintenance > Clean printheads, then select which printheads you want to clean. You can clean all of the printheads or only some of them. Your choices are:
  • Print test plot
  • Clean all
  • Clean LC-C
  • Clean Y-MK
  • Clean LM-M
Cleaning all printheads takes about 5 minutes. Cleaning any two printheads takes about 3 minutes.
Cleaning all printheads uses more ink than cleaning a single pair.
