    We are upgrading our website
HP Pro 2000/2080 Business PC - Product Features
Standard Configuration Features
HP Pro Business PC features may vary depending on the model. For a complete listing of the hardware and software installed in the computer, run the diagnostic utility (included on some computer models only). Instructions for using the utility are provided in the Troubleshooting Guide.
HP Pro 2000
Figure :
HP Pro 2080
Figure :
The drive configuration shown above may be different than your computer model.
Serviceability Features
The Microtower computer includes features that make it easy to upgrade and service. A Torx T-15 or flat blade screwdriver is needed for many of the installation procedures described in this guide.
Front Panel Components
Drive configuration may vary by model.
Figure :
1
5.25-inch Optical Drive1
6
Hard Drive Activity Light
2
5.25-inch Optical Drive Bay
7
Optical Drive Eject Button
3
3.5-inch Media Card Reader (optional)2
8
Microphone Connector
4
Recovery/Reset Button
9
Headphone Connector
5
Dual-State Power Button
10
USB (Universal Serial Bus) 2.0 Ports
1Some models have bezel blanks covering one or both of the 5.25-inch drive bays.
2Some models have a bezel blank covering the 3.5-inch drive bay.
Media Card Reader Components
The media card reader is an optional device available on some models only. Refer to the following illustration and table to identify the media card reader components.
Figure :
No.
Slot
Media
1
xD
  • xD-Picture Card (xD)
2
MicroSD
  • MicroSD (T-Flash)
  • MicroSDHC
3
Media Card Reader Activity Light
4
SD/MMC+/miniSD
  • Secure Digital (SD)
  • Secure Digital High Capacity (SDHC)
  • MiniSD
  • MiniSDHC
  • MultiMediaCard (MMC)
  • Reduced Size MultiMediaCard (RS MMC)
  • MultiMediaCard 4.0 (MMC Plus)
  • Reduced Size MultiMediaCard 4.0 (MMC Mobile)
  • MMC Micro (adapter required)
5
USB
  • USB (Universal Serial Bus) Port
6
CompactFlash I/II
  • CompactFlash Card Type 1
  • CompactFlash Card Type 2
  • MicroDrive
7
MS PRO/MS PRO DUO
  • Memory Stick (MS)
  • MagicGate Memory Stick (MG)
  • MagicGate Memory Duo
  • Memory Stick Select
  • Memory Stick Duo (MS Duo)
  • Memory Stick PRO (MS PRO)
  • Memory Stick PRO Duo (MS PRO Duo)
  • Memory Stick PRO-HG Duo
  • Memory Stick Micro (M2) (adapter required)
Rear Panel Components
Figure :
1
Mouse PS/2 connector
7
Keyboard PS/2 connector
2
VGA Monitor Connector
8
Serial connector
3
RJ-45 Network Connector
9
DVI Connector
4
Line-In Audio Connector (blue)
10
Universal Serial Bus (USB) Ports
5
Voltage Switch
11
Microphone Connector (pink)
6
Power Cord Connector
12
Line-Out Connector for powered audio devices (green)
Arrangement and number of connectors may vary by model.
When a device is plugged into the blue Line-In Audio Connector, a dialog box will pop up asking if you want to use the connector for a line-in device or a microphone. You can reconfigure the connector at any time by double-clicking the Realtek HD Audio Manager icon in the Windows taskbar.
Country: Flag Serbia
