HP Compaq nc4400 Notebook PC - Removing and Replacing the Button board
This document is provided to assist in removing and replacing the Button board for the HP Compaq nc4400 Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P0,P1) screwdrivers.
Small, flat-bladed screwdriver or a flat-bladed alignment tool.
Parts required
The replacement part number will vary depending on the Button board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Button board (includes button board cable)
419112-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the Button board, click on the link below. Or use the product video listing on the (Click here to go to HP Service Media Library), then select Button board from the menu on the upper left hand side of the screen.
Click here to view the Button board removal video (right-click on the link to open in a new window/tab).
  2. Disconnect the button board cable from the system board and un-route the cable from the top cover.
  3. Remove the 3 mm P0 Phillips-head screw that secures the button board to the top cover.
  4. Lift and remove the button board and cable.
  5. Disconnect the button board cable from the button board.
  6. Place the button board in a static dissipative bag.
Button board replacement
  1. Remove the button board from the static dissipative bag.
  2. Reconnect the button board cable to the button board.
  3. Place the button board into position on the top cover under the plastic tab and over the guide pin.
  4. Replace the 3 mm P0 Phillips-head screw that secures the button board to the top cover.
  5. Reconnect the button board cable to the system board and route the cable on the top cover.
