    Apache Log4j Update
HP Jetdirect ew2500 802.11g Wireless Print Server - Configure settings for a wired network
A network connection is required before you can discover and install the printer on your network systems. To configure a wired connection, verify the following:
  • You have a computer with one of the following operating systems:
    • Microsoft Windows XP, Vista, Server 2003, or Server 2008
    • Apple Mac OS X 10.2 or greater
  • You have installed the HP Jetdirect print server hardware and have printed an HP Jetdirect configuration page.
Set up each Windows computer for printing on the networked printer by inserting the CD-ROM and selecting Install. This basic procedure involves configuring network parameters for the print server, installing printer drivers and other software, and setting up the print path. You will use the installation software on the CD-ROM supplied with your printer.
