    Apache Log4j Update
HP Jetdirect ew2500 802.11g Wireless Print Server - Install the printer on a network system or server
After your printer is connected to your network (wired or wireless), you can install the printer on the dedicated print server.
Before you begin
Obtain the printer driver from the following sources:
Microsoft client-server networks
After you have set up the printer on the server, set up your network clients to access the printer through the server. The procedures depend on the utilities available for your particular clients and network operating system.
For example, if the printer is installed and shared on a Microsoft server, each Windows client can use Add Printer or Network Neighborhood utilities to access the printer.
For more information, refer to the documentation and help supplied with your network operating system.
