    Apache Log4j Update
HP Jetdirect ew2500 802.11g Wireless Print Server - Install the print server hardware
Set up the printer
Do not install any printer software until all of the hardware connection steps have been completed.
If the printer is already set up
  1. Turn off the printer.
  2. Detach it from any computer.
  3. Turn on the printer.
If the printer is not already set up
  1. Assemble the hardware only using the instructions supplied with the printer.
  2. Set aside the printer CD. (Do not install its software yet. Do not attach the printer to your computer.)
  4. Print a test page as instructed.
Connect the print server to the printer
  1. Connect the USB cable.
    • Plug the supplied USB cable into the USB connector on the back of the print server.
    • Plug the other end of the cable into the printer’s USB connector.
    Do not use a USB hub, extender or parallel converter.
    Figure : Connect USB cable
  2. Connect the power cable.
    • Plug the supplied power module into a power outlet.
    • Plug the other end of the power cable into the power connector on the back of the print server.
    Figure : Connect power cable
  3. Print a configuration page by pressing the test button once. (The test button is located on the back of the HP Jetdirect ew2500 print server.)
  4. Proceed to Make a network connection.
