This document pertains the HP Notebook PCs with Windows 7.
If the computer is not using the Windows 7 operating system, see:
note:If you do not have a wireless internet connection, you can connect the computer temporarily to the network with a network cable. If you do not have a wired internet connection, use another computer to access the HP Software & Driver Downloads web site to find the drivers for the wireless device and the ethernet chipset. Download the drivers to an external drive and install them on the computer with the connection problem.
The original factory image of the HP computer has the required drivers for the built-in wireless network device and the HP Wireless Assistant. If you have changed the operating system (OS), download and install the latest version of the wireless network device driver and the HP Wireless Assistant for your model and OS.
Wireless Device Turned Off
Wireless Device Turned On
