HP ProBook 5310m Notebook PC - Overview
Product description
HP ProBook 5310m Notebook PC is an incredibly sleek notebook which has a sophisticated aesthetic with a durable anodized aluminum display enclosure and palm rest.
This notebook is packed with a powerful standard voltage or affordable ultra-low voltage Intel processor, a 2 MP webcam with dual-microphone array for clear web conferencing, strong security features to help protect your data, and a stylish, lightweight metal design that redefines notebook style.
Product features
Feature
Mobile Intel GS45 Express Chipset ICH9M-Enhanced
Processors
  • Intel Core 2 Duo Processor SP9300 (2.26-GHz, 6MB L2 cache, 1066 MHz FSB)*
  • Intel Celeron Processor SU2300 (1.20-GHz, 1MB L2 cache, 800 MHz FSB)
* Intel's numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
System Memory
Standard: 1GB, 2GB, or 4GB DDR3 1066/1333 MHz SDRAM SODIMM* one SODIMM slot
Maximum: Supports up to 4GB maximum
* All memory modules operate at the maximum system supported speed of 1066 MHz.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. Availability of 4GB of memory requires a Windows 64-bit operating system or Linux. With Windows 32-bit operating systems, memory above 3GB may not all be available due to system resource requirements.
Graphics
Internal:
  • 13.3 in diagonal LED-backlit HD anti-glare (1366 × 768 resolution)
  • 13.3 in diagonal LED-backlit HD BrightView (1366 × 768 resolution)
  • HP Privacy Filter support
External: Up to 32-bit per pixel color depth
  • DisplayPort supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz with full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Keyboard
The 101/102-key compatible keyboard features an industry standard, full-pitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. US and International key layouts are available. Other features include an integrated numeric keypad, hotkeys for instant access to power conservation, brightness, and other features, 19 mm x 19 mm key pitch (center-to-center spacing), 2.0 mm stroke, and comfort-dished keycaps.
HP DuraKeys is a clear coating applied over the notebook keyboard that helps protect the finish and the printed characters on the keys.
Graphics
  • Mobile Intel Graphics Media Accelerator 4500MHD
  • Microsoft DirectX 10 (Shader 4.0) and OpenGL 2.0 capable
Pointing device
Touchpad with scroll zone, two pick buttons
Expansion card slots
Secure Digital slot: Supports SD (Secure Digital), MMC (MultiMedia Card)
Storage
Internal Storage Device: 160/250/320GB 7200 rpm 2.5 in SMART SATA II Hard Drive or 80/128GB 2.5 in Solid State Drive.
Hard drives are customer removable and will withstand multiple insertion/removal cycles. Up to 10GB is reserved for the system recovery software.
HP 3D DriveGuard (Windows models only): The hard drive is mounted to the notebook frame, reducing the transmission of shock away from the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Optical drive: Optional HP External USB 2.0 CD/DVD R/RW Drive
Power Supply
External 65 W
Battery
Primary Battery:
  • 6-cell (62 WHr) high capacity Lithium-Ion
  • 4-cell (41 WHr) high capacity Lithium-Ion
Software overview
Feature
Operating System
  • Genuine Windows 7 Professional Edition 32
  • Microsoft Windows XP
  • Windows Vista
Warranty information
HP Services includes a one-year standard parts and labor warranty, pick-up or carry-in, and toll-free 24/7 hardware technical phone support. On-site service and warranty upgrades are also available.
