HP Compaq 6000 Pro Microtower PC Product Specifications
Product features
Feature
Intel Q43 Express chipset
Processors
Intel Celeron Processors:
  • Intel Celeron 450 Processor (2.2-GHz, 512K L2 cache, 800 MHz FSB)
Intel Celeron Dual-Core Processors:
  • Intel Celeron E3200 Processor (2.4-GHz, 2MB L2 cache, 800 MHz FSB)
  • Intel Celeron E3300 Processor (2.5-GHz, 2MB L2 cache, 800 MHz FSB)
Intel Pentium Dual-Core Processors:
  • Intel Pentium dual-core E5300 Processor (2.6-GHz, 2MB L2 cache, 800 MHz FSB)
  • Intel Pentium dual-core E5400 Processor (2.70-GHz, 2MB L2 cache, 800 MHz FSB)
  • Intel Pentium dual-core E6300 Processor (2.80-GHz, 2MB L2 cache, 800 MHz FSB)
Intel Core 2 Duo Processors:
  • Intel Core 2 Duo E7500 Processor (2.93-GHz, 3MB L2 cache, 1066 MHz FSB)
  • Intel Core 2 Duo E7600 Processor (3.06-GHz, 3MB L2 cache, 1066 MHz FSB)
  • Intel Core 2 Duo E8400 Processor (3.0-GHz, 6MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Duo E8500 Processor (3.16-GHz, 6MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Duo E8600 Processor (3.33-GHz, 6MB L2 cache, 1333 MHz FSB)
Intel Core 2 Quad Processors:
  • Intel Core 2 Quad Q8400 Processor (2.66-GHz, 4MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Quad Q9400 Processor (2.66-GHz, 6MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Quad Q9550 Processor (2.83-GHz, 12MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Quad Q9650 Processor (3.0-GHz, 12MB L2 cache, 1333 MHz FSB)
Intel processor numbers are not a measure of performance. Processor numbers differentiate features within each processor family, not across different processor families.
Memory
Supports un-buffered non-ECC DDR3 SDRAM
  • HP 4GB PC3-10600 (DDR3 1333 MHz) DIMM
  • HP 2GB PC3-10600 (DDR3 1333 MHz) DIMM
  • HP 1GB PC3-10600 (DDR3 1333 MHz) DIMM
Maximum Memory
Supports up to 16GB of un-buffered non-ECC DDR3 SDRAM.
Solid State Drive
64GB Solid State Drive
Removable Storage
Pocket Media Drive:
  • 250GB Pocket Media Drive
Media Reader:
  • HP 22-in-1 Media Card Reader (USB connection on the system board)
  • HP 22-in-1 (with 1394) Media Card Reader (USB connection on the system board)
Optical drive
  • SATA DVD-ROM Drive
  • SATA SuperMulti LightScribe DVD Writer Drive
  • SATA Blu-ray Writer
Keyboard/Mouse
Keyboard:
  • HP PS/2 Standard Keyboard
  • HP USB Standard Keyboard
  • HP Smartcard Keyboard
Mouse:
  • USB 2-Button Laser Mouse
  • PS/2 2-Button Optical Scroll Mouse
  • USB 2-Button Optical Scroll Mouse
Power Supply
320 W BTX Active PFC
Communications
Features
Communication
Wireless LAN:
  • HP 802.11 b/g/n Wireless PCIe x1 card (full height bracket)
  • HP 802.11 b/g/n Wireless PCIe x1 card (low profile bracket)
NICs:
  • Intel 82567LM Gigabit Network Connection (integrated on system board)
  • Broadcom NetXtreme Gigabit Ethernet Plus PCIe NIC
  • Broadcom NetXtreme Gigabit Ethernet Plus (DASH 1.1) PCIe NIC Card (with cable for internal USB header)
  • Intel Gigabit CT Desktop NIC
Modem: LSI PCIe x1 56K International SoftModem
Graphics
  • Integrated Intel Graphics Media Accelerator 4500
  • ATI Radeon HD 4650 (1GB DH) PCIe x16 Graphics Card
  • ATI Radeon HD 4550 Dual Head PCIe x16 Graphics Card
  • NVIDIA Quadro NVS 290 PCIe x1 Graphics Card
  • NVIDIA Quadro NVS 290 (256MB DH) PCIe x16 Graphics Card
  • NVIDIA Quadro NVS 295 (256MB DH) PCIe x16 Graphics Card
  • HP ADD2 SDVO PCIe DVI-D adapter
  • HP DisplayPort to VGA Adapter
  • HP DisplayPort to DVI-D Adapter
Audio
Features
Audio
  • Integrated High Definition audio with Realtek ALC261 codec (all ports are stereo)
  • Microphone and Headphone front ports
  • Internal Speaker
Hardware Specifications
Features
Chassis Dimensions (HxWxD)
377.2 x 176.5 x 430.8 mm (14.85 x 6.95 x 16.96 in)
Temperature
Operating: 10° to 35°C (50° to 95°F)*
Non-operating: -30° to 60°C (-22° to 140°F)
* Operating temperature is de-rated 1.0°C per 300 m (1000 ft) to 3000 m (10,000 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 10°C/Hr. The upper limit may be limited by the type and number of options installed.
Humidity
Operating: 10% to 90% (non-condensing at ambient)
Non-operating: 5% to 95% (non-condensing at ambient)
Altitude
Operating: 3048 m (10,000 ft)
Non-Operating: 9144 m (30,000 ft )
System weight
9.3 kg (20.5 lb)
Power
320 W BTX power supply - Active PFC
Security
  • Kensington lock
  • HP Business PC Security Lock
  • HP Chassis Security kit
  • HP ProtectTools 5.0 Client Security Software
Software overview
Feature
Operating System
  • Microsoft Windows XP
  • Windows Vista
