Document ID: c01857585
Version: 1
HP EliteBook 6930p Notebook PC System BIOS Update F.13
Release date : 27-Aug-2009
Last updated : 31-Aug-2009
DETAILS OF CHANGE
  • Added a new feature that includes support for the next generation of Microsoft Windows operating systems.
  • Fixed an issue where the Type 1 field in the SMBIOS table would not report Wake-on-LAN.
  • Added the serial number to the Type 2 field in the SMBIOS table. This enables customers to use utilities that look for the serial number in this location.
  • Fixed an issue where the computer may automatically restart (without user intervenion) when it is in Standby or in the Sleep state.
    This issue is highly intermittent and the failure rate is less than 1 percent.
REASON FOR CHANGE
To implement changes under "Details of Change."
IMPACT OF CHANGE
Non-critical
Components affected:
DATE OF CHANGE
Effective date : 25-Sep-2009
Hardware platforms affected : HP EliteBook 6930p Notebook PC
