HP Indigo WS6000 Digital Press - Chiller control panel
The control panel consists of the following elements:
    Figure : Chiller control panel
  1. Main power switch — Connects and disconnects the chiller unit from the power supply
  2. Control thermostat — Indicates the cold water temperature at the outlet of the ultracool unit, and enables it to be regulated
  3. Flow diagram — Helps identify the alarms and signals that appear in the thermostat display
  4. Water filter pressure gauge — Indicates the pressure drop of the water filter and the evaporator
  5. Water pressure gauge — Indicates the pressure supplied by the pump
