HP Indigo WS6000 Digital Press - Draining water and process oily waste
Wear safety gloves and glasses for this procedure.
After the lower service door has been opened, you only have five minutes to drain the fluids when the press is running, or else waste materials may drain into the lower service door area.
To drain the cooler waste:
  1. Open the lower service door at the rear of the press.
      Figure : Lower service door at press rear
    1. Bottle openings must face the left
    2. Lower service door
    3. Process oily waste bottle (1)
    4. Water waste bottle (2)
  2. Remove the waste bottles from the press. Drain the water waste and process oily waste in separate external disposal tanks.
    • Dispose of process oily waste according to local regulations.
    • Do not mix up the containers.
    • Process oily waste must be properly discarded, and must not be dumped down a drain.
  3. Return the waste bottles to their proper positions:
    • The water waste bottle on the left,
    • The process oily waste bottle on the right,
    • The bottle openings must facing the left, as viewed from the back of the press.
    • Make sure bottle labels match the labels on the cabinet.
    • Do not put caps on the bottles; they receive waste fluids directly from the press when the lower service door is closed.
  4. Close the lower service door.
