HP Scanjet N6310 Scanner - Configuring "Scan To....Setup" in Scanner Software
This document provides information on configuring Scan To....Setup options in the HP Scanner Software.
Details
Launch the HP Scanner software to bring up the following window.
Fig-1: Main Window.
Click the "Options" menu to bring up the Scan To...Setup sub-menu as shown in the following figure:
Fig-2: Options window.
Select the Scan To...Setup option to launch the following window:
Fig-3: Scan To...Setup window.
To add/remove a scan shortcut to/from the front panel list, select a shortcut and click Add/Remove. After making the changes click the Update the Device button to save and apply the changes made.
