    Fix HP Printer issue on macOS
HP Indigo WS6000 Digital Press - Binary ink developer (BID) overview
The press uses binary image development (BID) in the image generation process. The press builds ink inside the BID and transfers the ink to the image areas on the PIP. The excess ink flows back into the BID and out to the ink tank. Each BID participates in the generation of a different separation, although the units are identical.
Replace the BID when:
  • Image quality deteriorates
  • Change of ink color is required
You can reuse a BID if you changed an ink color and you are then changing back to the original ink color.
Adjust the BID engage and disengage angles when:
  • A full printed image is not obtained on the leading edge or the trailing edge.
  • A single inkless patch appears in the 25 mm (1 inch) strip of the image's leading edge.
Use the BID troubleshooting guide to determine and correct the cause of print quality issues related to the BID.
The seven BID stations are numbered from 1 to 7.
    Figure : BID stations
  1. White
  2. Cyan
  3. Magenta
  4. Yellow
  5. Black
  6. Orange
  7. Violet
