HP Neoware c50 Thin Client - Specifications
Technical Specifications
Feature
Specification
Processor
VIA Eden 400 MHz Processor
Chipsets
CN700 Chipset
Memory
Flash Memory
128MB – 1GB
System Memory
256MB – 1GB (DDR2 RAM)
Graphics
VIA S3 Graphics
Mode
Refresh rate
Color depth
8-Bit color
85 Hz
Up to 1600 x 1200
16-Bit color
85 Hz
Up to 1600 x 1200
32-Bit color
60 Hz
Up to 1600 x 1200
85 Hz
Up to 1280 x 1024
Input/Output Peripheral Support
Keyboard
PS/2 US 104 Keyboard
Mouse
PS/2
Printer
Local support in ICA, RDP and local applications (may require additional drivers from manufacturer.)
Video
Up to 1600 x 1200 resolution or 32-Bit true color Wide Screen Monitor Resolutions: (NeoLinux 3 & XPe) 1440 x 900, 1680 x 050 & 1920 x 1200
Audio
Output
Speaker Out – 1/8 inch (3.55 mm) jacks Internal Speakers
Security (hardware)
  • Slot for Kensington Cable Lock
  • ActivIdentity USB Smart Card Reader, vendor models GBURR200 & GBUR300P025
  • GemAlto Smart Cards (Windows XPe models only)
  • BioPassword (Special XPe Snap-in)
Server-based Computing Protocols
  • ICA
  • RDP (CE & XPe) / RDesktop (NeoLinux)*
  • X.11/XDM (NeoLinux Only)
  • HP Neoware TeemTalk Terminal Emulator
Networking
  • Autosensing
  • 10/100 Ethernet
  • RI-45
  • WakeOnLAN
  • PXE Boot
  • External USB Wireless Options (a/b/g)
I/O Ports and Connectors
  • 1 – Serial Port – D-Sub 9-Pin – Male Connector
  • 1 – Parallel Port – D-Sub 25-Pin – Female Connector
  • 2 – USB Ports – Type A 2.0
  • PS/2 Ports (1 – Keyboard, 1 – mouse)
Resident Operating System
  • NeoLinux 3
  • Windows CE
  • Windows XPe
Server OS Compatibility/ Support
  • Citrix Presentation Server 4.0 including the Desktop Broker feature
  • Citrix Metaframe Presentation Server 3.0
  • Citrix Metaframe XP Presentation Server
  • Citrix Metaframe 1.x
  • Windows 2000/2003 Server Terminal Services
  • Windows 2000 Advance Server Terminal Services
  • Windows NT 4.0 Terminal Server Edition
  • VMware Virtual Desktop Infrastructure using RDP
  • Linux Terminal Server Project (LTSP) *
  • Most mainframes and midrange servers **
* Requires bios change to PXE boot
** Requires TeemTalk (standard on most HP Neoware thin clients)
Dimensions W x H x D (approximate)
1.4 x 9.5 x 8.2 in (3.6 x 24.1 x 20.8 cm)
Weight (approximate)
8.2 lbs (3.7 kgs) with keyboard
Environmental
Temperature range
Operating: 32° - 95°F (0° - 35°C)
Humidity
20 - 80% non-condensing
Power*
100 - 240 VAC, 50 - 60 Hz, 22 W typically
*The actual power consumption at your location could vary and is dependent on many factors including but not limited to software load on the thin client, attached peripherals, and environmental factors.
Regulatory Compliance
Product safety
  • UL60950-1, CSA22.2/60950-00, IEC 60950-1:2001, NOM-019-SCFI:1998, EN60950-1:2001, GOST-R, SABS LOA, AS/NZS 60950, CCC: GB4943, JS60950, SS60950
  • IN-Process: IRAM/S-Mark, SASO 60950-1:2001
Ergonomics   RF Interference
  • FCC Part 15C, I.C.: RS210, EN 300 328, EN 300 328, FCC15.247, COFETEL FCC 15.247, WPE: FCC Part 15.247, ICASA (Part 15.247), SRO 797:2004, QAT29/30/31, C-Tick: EN 300 328, SRRC (EN 300 328), OFTA 1035, POSTEL (EN300 328), TELEC (Article 19/19.2), SIRIM( Part 15.247), NTC (Part 15.247), iDA (TS SRD), NTC (EN300 328)
  • IN-Process: CNC-Q2-63.01 (wireless only)
  • Initiating request: Anatel: Resolution 305
Hardware: 3 year limited warranty
Software: 12 months
Certain restrictions apply. Consult the HP Customer Support Center for details.
