HP Indigo WS6000 Digital Press - Printing jobs
To Print jobs
  • Load jobs in the Print Queue. The position of a job in the list depends on urgency, substrate type, substrate thickness, number of colors in the job, or other job properties.
  • Arrange the jobs in the list to facilitate the workflow. For example, all jobs that use the same substrate type or all jobs that use the same fifth and sixth color should be grouped and printed consecutively.
    Jobs are loaded and managed using the HP SmartStream IN100 Labels and Packaging Print Server, Powered by EskoArtwork.
Stage 1: Loading jobs
From the HP SmartStream IN100 Labels and Packaging Print Server, Powered by EskoArtwork, load jobs to the Loaded Jobs list. There are several ways to load jobs to the list. Refer to the HP SmartStream IN100 Labels and Packaging Print Server, Powered by EskoArtwork user guide for details.
  • Make certain the job properties, number of copies, print range, and screen ruling are defined as required.
  • Modify the properties if necessary.
Stage 2: Printing the full run
  1. Set the print mode:
    Figure : Print mode selector
    • When the print mode is set to Continuous, the job is unloaded at the end of the print run and the next job in the Print Queue starts the print process.
      • When the print mode is set to Step, the next job in the Print Queue is moved to the top of the Print Queue and appears in the Now printing job field, but printing stops.
  2. Change the press status to Ready.
  3. Make certain the required substrate type for the subsequent job is loaded on the press.
  4. On the control panel, touch Print to print the full-run.
