HP Photosmart Premium All-in-One (C309) and Photosmart Premium e-All-in-One (C310) Printer Series - 'Printhead Problem' or 'Printhead Appears to be Missing or Damaged' Message Displays on the Computer
This document is for the HP Photosmart Premium All-in-One (C309) and Photosmart Premium e-All-in-One (C310) Printers.
The message 'Printhead problem' or 'Printhead appears to be missing or damaged' displays on the computer and the printer does not print. This document addresses these printhead malfunction issues.
Solution one: Remove, clean, and then reinstall the printhead
Follow these steps to remove, clean, and then reinstall the printhead.
  1. Press the Power button to turn on the printer, if it is not already on.
  2. Open the cartridge access door. The carriage moves to the center of the printer. Wait until the carriage is idle and silent before you continue.
  3. Remove all the cartridges and place them on a piece of paper with the ink opening pointing up.
    Do not leave the cartridge outside of the printer longer than 30 minutes. This could damage both the printer and the cartridges.
    Figure : Remove the cartridge
    Image: Remove the cartridge
  4. Lift the latch handle on the carriage until it stops.
    Figure : Lift the latch handle
    Image: Lift the latch handle
  5. Lift up to remove the printhead.
    Figure : Remove the printhead
    Image: Remove the printhead
  6. Clean the printhead.
    There are three areas of the printhead to clean: the plastic ramps on both sides of the ink nozzles, the edge between the nozzles, and the electrical contacts.
      Figure : Three areas to clean
      Image: Clean the three areas of the printhead to clean: the plastic ramps on both sides of the ink nozzles, the edge between the nozzles, and the electrical contacts
    1. Plastic ramp on the side of the ink nozzles
    2. Edge between the ink nozzles and the electrical contacts
    3. Electrical contacts
    Do not touch the nozzles. Do not touch the electrical contact areas with your fingers. Touch the electrical contact areas only with cleaning materials.
    To clean the printhead, follow these steps:
    1. Gather cleaning materials:
      • Clean, lint-free cloth or paper (Coffee filters and eye-glass cleaning cloth work well.)
      • Distilled or bottled water
    2. Lightly dampen a clean, lint-free cloth, and then wipe the electrical contact area from the bottom to the top. Do not clean beyond the edge between the nozzles and the electrical contacts. Clean until no new ink shows on the cloth.
      Figure : Clean the printhead contacts
      Image: Clean the printhead contacts.
    3. Use a fresh, lightly dampened, lint-free cloth to wipe any accumulated ink and debris from the edge between the nozzles and the contacts.
      Figure : Clean the edge of the printhead
      Image: Clean the edge of the printhead.
    4. Use a fresh, lightly dampened, lint-free cloth to wipe the plastic ramps on both sides of the nozzles. Wipe away from the nozzles.
      Figure : Clean the printhead ramps
      Image: Clean the printhead ramps.
    5. Wipe the previously cleaned areas dry with a dry lint-free cloth before you proceed to the next step.
  7. Clean the electrical contacts inside the printer:
    1. Lightly dampen a clean, lint-free cloth with bottled or distilled water.
    2. To clean the electrical contacts in the printer, wipe with the cloth from top to bottom. Use as many fresh, clean cloths as necessary. Clean until no ink shows on the cloth.
      Figure : Clean contacts inside the printer
      Image: Clean contacts inside the printer.
    3. Wipe the area dry with a dry lint-free cloth before you proceed to the next step.
  8. Make sure that the latch handle is up, and then install the printhead.
    Figure : Insert the printhead
    Image: Insert the printhead
  9. Carefully lower the latch handle.
    Make sure that you lower the latch handle before you install the cartridges. If the latch handle remains raised, incorrectly seated cartridges and printer problems can occur.
    Figure : Lower the latch handle
    Image: Lower the latch handle
  10. Slide each cartridge into the correct slot until it clicks into place. Make sure that the colored shape icon on the cartridge label matches the colored shape icon on the carriage slot.
    Figure : Reinstall each cartridge
    Image: Reinstall each cartridge
  11. Close the cartridge access door.
Solution two: Reset the printer
A printer reset can resolve some printhead issues. Follow these steps to reset the printer.
  1. Turn the printer on, if it is not already on.
  3. With the printer turned on, disconnect the power cord from the rear of the printer.
  4. Unplug the power cord from the wall outlet.
  5. Wait at least 60 seconds.
  6. Plug the power cord back into the wall outlet.
    HP recommends connecting the printer power cord directly to the wall outlet.
  7. Reconnect the power cord to the rear of the printer.
  8. Turn on the printer, if it does not automatically turn on.
    The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
  9. Wait until the warm-up period finishes and your printer is idle and silent before you proceed.
Solution three: Replace the printhead
If you have completed all the previous steps and the issue persists, replace the printhead.
Wait until you have a new printhead assembly available before you remove the cartridges. HP recommends that you do not leave the cartridges outside the printer longer than 30 minutes. This could damage both the printer and the cartridges.
If you have a defective cartridge or printhead, it might be under warranty. To check the warranty on your ink or toner supplies, go to hp.com/go/learnaboutsupplies, select your country/region, and then review the limited warranty information for your supplies.
These steps apply to all countries/regions except the United States.
If HP replaces your printhead assembly under warranty, you receive a new printhead assembly, cleaning materials, and a full set of new cartridges with the replacement printhead.
If your printhead assembly is no longer under warranty, you can purchase a new one online.
  1. Go to the HP How to Buy website, and then click your country-language.
  2. A Buy HP page displays. Look for the HP Parts store on this page. The location of the HP Parts store varies depending on your region. Click HP Parts store.
  3. Under Find your part(s), type CN642A in the Search by part number text box. Follow the on-screen instructions to order the printhead assembly.
When you have the replacement printhead, go to replacing the printhead assembly for detailed instructions.
Step five: Service the printer
Contacting HP for service in all countries/regions except Asia Pacific.
If you completed all the preceding steps and your product still has an issue, service the product.
Check your product warranty to determine if your product is still under warranty, and then go to Contact HP Support to schedule a repair or replacement.
