HP ProBook 4410s Notebook PC - Removing and Replacing the Switch cover
This document is provided to assist in removing and replacing the Switch cover for the HP ProBook 4410s Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P000, P00 and P1) screwdrivers.
Parts required
The replacement part number will vary depending on the Switch cover that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Switch cover (Black) - For use on models with 15 inches displays
535861-001 (Modified)
No
For use in red computers with 15 inches displays
572726-001 (Original)
No
For use in black computers with 14 inches displays
535860-001 (Modified)
No
For use in red computers with 14 inches displays
572725-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Switch cover, click on the link below. Or use the product video listing on the HP Services Media Library then select Switch cover from the menu on the upper left hand side of the screen.
Click here to view the Switch cover removal video (right-click on the link to open in a new window/tab).
  2. Remove the two 3mm P1 Phillips broad head screws in the battery bay that secure the switch cover to the base enclosure.
  3. Remove the two Phillips-head screws in the rear of the battery bay that secure the switch cover to the base enclosure.
    The video shows a preproduction model of the notebook. The final version of the notebook will include these screws.
  4. Remove the two 3mm P00 Phillips-head screws from the rear panel that secure the switch cover to the base enclosure.
  5. Turn the notebook right side up and open the display fully.
  6. Slide the switch cover toward the rear of the notebook.
  7. Remove the switch cover from the base enclosure.
Switch cover replacement
  1. Place the switch cover onto the base enclosure.
  2. Align the sides, hinge cut outs, and toes with the sides, hinges, and slots of the base enclosure.
  3. Press down on the switch cover and slide it toward the center of the notebook.
  4. Close the display and turn the notebook upside down.
    Ensure that the four tabs on the rear edge of the switch cover are properly seated in their respective notches in the battery bay.
  5. Replace the two 3mm P00 Phillips-head screws into the rear panel that secure the switch cover to the base enclosure.
  6. Replace the two Phillips-head screws into the rear of the battery bay that secure the switch cover to the base enclosure.
  7. Replace the two 3mm P1 Phillips broad head screws into the battery bay that secure the switch cover to the base enclosure.
Parts return
