    Fix Windows 10 Update Issues
HP LE2001w 20-inch Widescreen LCD Monitor - Overview
Product Description
New energy-saving HP LE2001w 20-inch LCD display helps you to successfully complete the day-to-day tasks, to reduce the volume of energy consumption.
HP LE2001w is designed with the Energy Star standards.
Compared with the previous generations of models, greatly reduced its mercury content, and eliminated arsenic in the plate.
Product Features
Feature
Type
20.0-inch Wide-Aspect Active Matrix TFT (thin film transistor)
Size / Viewable Image Size (diagonal)
20.0 inches widescreen; diagonally measured
Native Resolution
1600 x 900 @ 60 Hz (WSXGA+)
Signal Input
VGA connector
Horizontal Viewing Angle
Up to 170° horizontal/160° vertical (700:1 minimum contrast ratio)
Cabinet Colors
Black
Image Quality
Brightness (typical)
250 nits (cd/m2)
Contrast Ratio (typical)
1000:1
Pixel Pitch
0.2768 mm
Horizontal Frequency Range
24 to 85 kHz
Vertical Frequency Range
50 to 76 Hz
Ease of Use Feature
User Programmable Modes
8
Plug and Play
Yes
Language Selection
Yes
Ergonomic Features
Anti-Glare
Yes
Anti-Static
Yes
Tilt/Swivel
Yes
Tilt Range
-5° to + 25° vertical
Swivel Range
No
Height Adjustable
No
Pivot Rotation
No
Base
Detachable, ships detached
Warranty Information
Limited 3 years parts, labour and on-site service, including backlight.
Links to Product Specifications
