Blinking Lights on the HP Deskjet F2400 All-in-One Printer Series
Blinking Lights
The following sections describe the most common combinations of blinking (flashing) lights on the control panel, followed by solutions for each combination. Find the blinking lights pattern you are experiencing, and then follow the steps to resolve the issue.
    Figure : Control panel with lights indicated
    Image of control panel with the lights indicated
  1. Power light
  2. Attention light
  3. Check Color Cartridge light
  4. Check Black Cartridge light
