    Looking for Site Help?
HP Web Jetadmin 10.xx - "Unexpected error has occurred the client will be closed"
Issue
When running Web Jetadmin (WJA) on the server itself or on a remote client, an event may occur that will cause WJA to post the following message.
Solution
Although it is possible that there could be other root causes for this error to occur, the most common cause is corruption within the .Net client files located under the following directory.
Windows XP/2003
\Documents and Settings\<user>\AppData\Local\Apps\2.0
Windows Vista/Windows 7/Windows 2008
\Users\<user>\AppData\Local\Apps\2.0
This issue can be resolved by deleting the 2.0 directory on the client where WJA is being run. The 2.0 directory will then be recreated the next time the WJA application is run on the client.
Country: Flag Serbia
