note:This topic applies to the HP Designjet 4020 Printer series only.
Lift up the three loop stoppers when printing small sheets.
Paper often tends to curl near the end of a roll, which can cause stacking problems. Load a new roll, or remove prints manually as they are completed.
If you are mixing prints or nesting sets of several different sizes, you may have stacking problems because of the different sizes of paper in the bin.
