HP Designjet T1120 MFP Product Series - System Software is in the Wrong Language
Your system’s language is setup during installation and changing the language will require that you Update the system through reinstalling the program with a new language selection.
  1. Press Options > Advanced Options > Software Update.
  2. Choose the System Update/Recover option in the Software Update & Recovery Mode menu.
  3. In the program version image list - Choose to install the “active” program image.
  4. Confirm your selection when asked. The system will proceed to update the system with the program image. This takes about 2 minutes. Press the OK button to return to the Software Update & Recovery Mode menu.
  5. Select the Return to normal scanner operation button and confirm. The system will load and initialize all its parameters. DO NOT TURN OFF THE SCANNER OR INTERUPT THE LOAD PROCESS. THIS STEP CAN TAKE UP TO 10 MINUTES TO COMPLETE.
  6. At the end of the system load process, you will be asked to calibrate the touch screen. Press the arrows and OK button when prompted.
  7. Select the new language for your system software.
  8. Accept the HP license agreement.
  9. Your system will complete the update process and start up your scan and copy program interface in the new language you selected in step 7.
