HP Designjet T1120 MFP Product Series - Specifying the Image Type and Making Image Adjustments
Basic capture parameters are set when you select the Original Type. You can then adjust specific factors such as image brightness, sharpening and background cleaning level. The adjustments available will depend on the Original Type selection.
  1. Press the Scan button or Copy button and then the Original Type button to reach the Original Type selection list.
    Figure : Original type screen
  2. Select an image Original Type that best describes your original (Color Poster, Gray Map, Old Drawing…. ). Below follows a description of each available Original Type.
    • Color Lines - Suitable for color CAD drawings and graphics with a high level of detail. Applies image processing to clean the background and sharpen lines. 24-bit color scan.
    • Gray Lines - Suitable for grayscale CAD drawings and graphics with a high level of detail. Applies image processing to clean the background and sharpen lines. 8-bit grayscale scan
    • B&W Lines - Suitable for clean B&W CAD drawings and graphics with a high level of detail. Especially useful for scan to file as file sizes are minimal compared to color and gray original types. Minimal application of image processing for a neutral and fast scan.1-bit B&W scan.
    • Color Map - Suitable for color maps such as topographic maps, road maps etc. or other document types that contain fill areas and a high level of detail. Applies image processing to sharpen details. 24-bit color scan.
    • Gray Map - Suitable for grayscale maps such as topographic maps, road maps etc. or other document types that contain fill areas and a high level of detail. Applies image processing to sharpen details. 8-bit grayscale scan.
    • Color Poster - Suitable for color photos and posters of good quality. Minimal application of image processing for a neutral and fast scan. 24-bit color scan.
    • Old Drawing - Suitable for faded and creased drawings with low contrast between the foreground and background. Applies image processing to clean the background and sharpen lines. 8-bit grayscale scan.
  3. You can fine tune the Original Type settings (optional): Press the More button to expand the Original Type dialog and make adjustment settings relevant to the selected Original Type.
    Figure : Original type dialog screen
  4. Press OK when done. Press the dialog's on-line help button for additional information about each setting and about saving your settings as a new custom Original Type.
You can press the preview button and then the preview image adjustments button to make image adjustments and view the effects on your screen. See the related topic "How do I preview copies and scans" for instructions.
In most cases, you will regard your Original Type selection as a description for the input original while actually, your Original Type definition also determines the output. For example, you will create a grayscale version of a color document when you load a color original and select a grayscale original type.
