HP Designjet T1120 MFP Product Series - Select Output Quality
To set quality with scan-to-file:
You apply quality settings to scanning (scan to file) in terms of the scan resolution measured in dots per inch (dpi).
  1. Press the Scan button and then the Quality button to open the Quality(dpi) dialog.
    Figure : Quality(dpi) dialog screen
  2. Use the scroll bar to view available resolutions.
  3. Press the button displaying the scan resolution you want to use.
  4. The Custom button opens a list with alternative resolutions.
Normally, you will not need to change the resolution because the resolution setting applied through your selected Original Type is optimal for the job.
To set quality with copying (scan-to-print):
With copying (scan-to-print), you set general print quality parameters (fast, normal, ...) that apply for the whole copy process. (scan and print).
  • The scan quality is defined by resolution (dpi). You can select the scan resolution you want tied to each quality setting (fast, normal, best). This is done through the Original Type adjustment options (see below).
  • The print quality parameters tied to a quality setting (fast, normal, best) are static and defined in the printer.
  1. Press the Copy button and then the Quality button to open the print Quality dialog.
    Figure : Quality dialog screen
  2. Select the required quality setting from the list.
    • Fast - for making a quick draft with minimum use of ink.
    • Normal - good for most copy jobs that require an average quality level.
    • Best - for high quality prints.
To tie scan resolutions to the Fast, Normal, Best copy quality settings (scan-to-print)
  • Press the Original Type button and then the More button to open the Original Type’s adjustment options.
    Figure : Original Type options screen
  • Scroll down the list of adjustments to reach the buttons labeled Fast Scan resolution, Normal Scan Resolution and Best Scan Resolution.
  • Press the button related to the quality setting (fast, normal, best) in which you want to change the scan resolution. This will open a list of resolution selections.
  • Select the scan resolution you want applied when you choose the named quality setting (fast, normal, best) with the current Original Type.
  • Example: Select the Color Poster original type and press the More button to make adjustments. Press the Best Scan Resolution button and then select 400 dpi. This means that thereafter, 400 dpi will be applied as the scan resolution whenever you use the Color Poster original type with the quality setting Copy > Quality > Best.
