HP Designjet T1120 MFP Product Series - File Manager
File Manager
To access and manage the image files on your system's scan Destinations and USB drive.
You press the File Manager action button to open the File Manager dialog.
Figure : File Manager dialog
Browsing the file system
  • Folders and files list: The File Manager is limited to folders that are defined on your system as scan Destinations. The file list defaults to the root of your current Destination folder.
  • The folder up button (marked "..") will move you up a level until your reach your list of created Destination folders.
  • Pressing on a folder name will move you onto its level.
  • Click on an image name to get a thumbnail preview and basic information about the image.
  • You select image files for a file action (see below) by checking the box to the left of the image file name.
File action buttons
  • Copy: To copy one or more selected (check-marked) files to another folder.
  • Move: To move one or more selected (check-marked) files to another folder.
  • Rename: To change the name of a selected (check-marked) file.
  • Delete: To delete one or more selected (check-marked) files from the system.
  • New Folder: To create a new subfolder in the current folder.
  • All/None: will toggle between checking and un-checking the boxes to the left of the all the file names in the current folder being viewed.
  • View: Opens a separate window with a larger view of the image file currently displayed.
