A comfortable fit for any budget, the HP 541 Notebook PC with integrated
graphics, or the HP 541 Notebook PC (where available) with ATI Mobility
Radeon X1350 dedicated graphics helps to stay connected and productive.
- ${title}
- ${title}
- ${title}
- ${title}
HP 541 Notebook PC - Overview
Product description
Product features
Feature
Mobile Intel PM965 Express Chipset
Processors
note: note: |
Memory
Standard: 512 MB, 1024 MB, 2048 MB, or 4096 MB* 667 MHz DDR2 SDRAM total memory; two SODIMM slots supporting dual channel memory
Dual-channel: Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
note: |
Graphics
ATI Mobility Radeon X1350, 64/128-bit 4-channel DDR2 dedicated graphics memory
Internal
External
note: |
Keyboard
The 101/102-key compatible keyboard features an industry standard, full-pitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. US and International key layouts are available. Other features include an integrated numeric keypad, hotkeys for instant access to power conservation, brightness, and other features, 19 mm x 19 mm key pitch (center-to-center spacing), 2.5 mm stroke, and comfort-dished keycaps.
Touch-sensitive controls
Touch-sensitive controls provide easy access to the following features: HP Info Center, HP Presentation button, wireless on/off, mute, and volume up, volume down
Pointing device
Touchpad with scroll zone, two pick buttons
Expansion card slots
ExpressCard/34 slot:
Storage
Hard drives: 120/160/250 GB 5400 rpm SMART SATA
note: |
HP DriveGuard: The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive.
Fixed optical drives:
Power Supply
External 90 W AC adapter
Battery
6-cell (47 WHr) high capacity Lithium-Ion
Software overview
Feature
Operating System
Link to product specifications
Warranty information
Links to product quickspecs
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
