HP v185e LCD Monitor - Overview
Product description
HP v185e LCD Monitor.
Product features
Feature
Panel
18.5 inches diagonal widescreen Thin-Film Transistor LCD active matrix (16:9 aspect ratio)
On Screen Display (OSD) Controls
Buttons or Switches: Input select, auto adjust/OSD down, OSD UP, OSD menu select, power.
Languages: English, Spanish, French, German, Dutch, Italian, Japanese, Simplified Chinese.
User Controls:
  • Brightness
  • Contrast
  • Positioning
  • Color temperature (6500k, 9300k, Custom)
  • Individual color control
  • Serial Number
  • Display
  • Clock
  • Clock Phase
  • Monitor Management
  • Factory Reset
Video/Other Inputs
Plug and Play.
Input Signal: VGA, VGA cable included .
Power Supply
Input power: Auto-Sensing, 100 to 240 VAC.
Frequency: 47 Hz to 63 Hz.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
