HP Designjet T1100, and T1120 Printer Series - Remove an ink cartridge
This document is for HP Designjet T1100, and T1120 Series printers.
There are two occasions when you need to remove an ink cartridge.
  • The ink cartridge is very low and you want to replace it with a full cartridge for unattended printing (you can use up the remaining ink in the first cartridge at a more convenient time).
  • The ink cartridge is empty or faulty, and you must replace it to continue printing.
Do not try to remove an ink cartridge while printing.
Remove an ink cartridge only if you are ready to insert another one.
Make sure the printer wheels are locked (the brake lever is pressed down) to prevent the printer from moving.
  1. Press the Menu key to return to the main menu and select the Ink menu icon , then Replace ink cartridges.
    Figure : Replace ink cartridges
  2. Open the ink cartridge cover on the left-hand side of the printer. All six inks, gray, photo black, matte black, yellow, magenta, and cyan, are on the left-hand side.
    Figure : Opening the cartridge cover
  3. Grip the cartridge you wish to remove.
  4. Pull the cartridge straight up.
    Figure : Removing an ink cartridge
    Avoid touching the end of the cartridge that is inserted into the printer, as there may be ink on the connection.
    Avoid storing partially used ink cartridges.
    Figure : Ink cartridge removed
  5. The front-panel display identifies the missing ink cartridge.
