    Windows 11 Upgrade Guide
HP Scanjet 8300 / 8350 Document Flatbed Scanners - Error message appears "ROM code failed, Please download FW"
Issue:
HP Scanjet Scanners 8300 / 8350 Document Flatbed Scanners: Error message appears "ROM code failed, Please download FW" and then scanner stops working
Solution
In order to resolve the issue, please download the Firmware update available on hp.com.
  1. Once this web page opens do the following:
    1. Click Download drivers and software (and firmware)
    2. Enter your product name / number (for example LaserJet 1320)
    3. Click Go
    4. Click on the link for the desired operating system.
    5. Find the desired software/driver/firmware and click Download to download to your PC.
Installation Instructions:
Instructions on the installation wizard must be followed carefully to avoid permanent damage to the scanner.
Once the file is downloaded, double-click on the file. Installation will begin automatically. Once the Firmware installation has completed, you can delete this file.
Cause
The ADF firmware can become corrupt in random and unexpected ways. For this reason, there may be many different symptoms that will indicate that this is in fact the problem with the unit.
