Document ID: c01678255
Version: 1
HP EliteBook 2530p Notebook PC System BIOS Update Version F.08
Release date : 23-Feb-2009
Last updated : 24-Feb-2009
DETAILS OF CHANGE
  • Enabled the F9 (Boot Options) and F12 (Network Boot) keys to be functional during system startup without first requiring the BIOS administrator password.
  • Added the capability to customize the startup (boot) screen.
    The ereplo08.exe utility is required to change the default HP logo to a customized logo.
  • Fixed an issue where pressing the caps lock key inadvertently disables the fn+num lk function, even though the num lk light remains lit.
  • Fixed an issue where the system takes a long time to boot when certain external USB hard drives are attached.
  • Fixed an issue where the BIOS configuration utility failed to capture settings in F10 setup.
  • Updated the Intel Manageability Engine (ME) firmware to version 1038 to fix an issue where the system hangs with a black screen after resuming from Standby.
  • Added WWAN Device initialization enable/disable in F10 setup.
REASON FOR CHANGE
REASON FOR CHANGE To implement changes under "Details of Change."
IMPACT OF CHANGE
None.
Components affected:
DATE OF CHANGE
Effective date : 31-Mar-2009
Hardware platforms affected : HP EliteBook 2530p Notebook PC
