Steps to set up the printer.
note:Do not connect the USB cable.
caution:Do not touch the copper-colored contacts or re-tape the cartridges.
Figure : Remove the pink tape
Figure : Do not touch contacts
note:Make sure all the paper in the stack is the same size and type and free from rips, dust, wrinkles, and curled or bent edges.
