- ${title}
- ${title}
- ${title}
- ${title}
HP Officejet 4400 (K410), Deskjet Ink Advantage (K209), and Deskjet F4400 All-in-One Printer Series - Setting up the All-in-One (Hardware)
Unpack the All-in-One
Check the contents of the box
Connect the power cord and adapter
Load plain white paper
Install the cartridges
Align the cartridges
Follow these steps in order.
Lift the product out of its box.
Remove all tape from the paper tray, and then open the front access door.Figure : Remove tape from paper tray
Remove the packing material from inside the front access door.Figure : Remove packing material
Close the front access door.Figure : Close the front access door
Step three: Connect the power cord and adapter
Turn the product to access its rear side.
Plug the power cord into the rear of the product.Figure : Connect the power cord to the rear of the product
Connect the power cord to the power adapter.Figure : Connect the power cord to the power adapter
Plug the other end of the power cord into an electrical outlet.Figure : Connect the power cord to the electrical outlet
Press the Power button (
) to turn on the product.
Figure : Turn on the product
Step four: Load plain white paper
Pull out the paper tray extender.Figure : Pull out the paper tray extender
Pull out the paper stop at the end of the paper tray extender.Figure : Pull out the paper stop
Slide the paper-width guide to its outermost position.Figure : Slide the paper-width guide to its outermost position
Load a stack of plain white paper into the paper tray with the short edge forward and print side down. Push the paper forward until it stops.Figure : Load paper
Adjust the paper-width guide so it rests against the stack of paper.Figure : Adjust the paper-width guide
Step five: Install the cartridges
Make sure the product is on.
Open the front access door.Figure : Open the front access door
Remove one of the cartridges from its packaging, and then pull the pink pull-tab to remove the protective tape from the nozzles.Figure : Remove the protective tape
Do not touch the cartridge contacts or nozzles.Figure : Do not touch the contacts -
Hold the cartridge by its sides.Figure : Hold the cartridge by its sides
Insert the cartridge into its designated slot. The black parallelogram icon (
) designates the slot for the black cartridge, and the magenta half circle icon (
) designates the slot for the color cartridge.
Figure : Insert cartridgeThe cartridge rests in its slot at a slight upward angle.Figure : Cartridge rests at upward angle -
Press the cartridge in to snap it into place.Figure : Snap cartridge into place
Repeat these steps to insert the other cartridge into its designated slot.
Step six: Align the cartridges
Wait while the product starts an automatic alignment process, and then prints an alignment sheet. The alignment process takes about 30 to 60 seconds to complete.Figure : Product prints an alignment sheet
If the product does not automatically start the alignment process, disconnect the power cord from the rear of the product, and then plug it back in. -
Lift the product lid.Figure : Lift the product lid
Place the alignment sheet on with the printed side down on the right-front corner of the scanner glass. See the engraved guide next to the scanner glass for help loading the alignment sheet.Figure : Load the alignment sheet
Lower the product lid.Figure : Lower the lid
Press the Scan button (
) to scan the alignment sheet.
Figure : Scan the alignment sheet -
Wait while the product scans the alignment sheet and completes the alignment process.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
