HP Color LaserJet CP1510 Printer Series and HP LaserJet Pro CP1525 Color Printer Series - 'Cleaning...' Message Displays on the Printer When Printing on Custom Size Paper in Windows XP
Issue
A 'Cleaning...' message displays on the product control panel after you print documents. The Ready light and the Attention light flash. This issue typically occurs when you print on custom-size paper.
By default, the product automatically cleans the intermediate transfer belt about every 150 pages printed. The process uses no paper.
Solution
Follow these steps to resolve the issue.
Step one: Reload the paper
Follow these steps to reload paper.
  1. Pull tray two out of the product and remove any paper.
    Figure : Pull out the tray and remove any paper
    Illustration: Pull out tray two and remove paper.
  2. Slide the paper length and width guides to their outermost positions.
    Figure : Slide out the paper guides
    Illustration: Slide out the paper guides.
  3. Load the paper with the short edge first and the print side up. Make sure that it is flat at all four corners.
  4. Slide the paper length and width guides snugly against the stack of paper.
    Figure : Slide the paper length and width guides against the paper
    Illustration: Slide in paper guides snug against the paper.
  5. Push down on the paper to make sure that the paper stack is below the paper limit tabs on the side of the tray.
    Figure : Make sure that the paper is below the tabs on the tray
    Illustration: Make sure that the paper is below the paper limit tabs.
  6. Slide the tray into the product.
    Figure : Slide the tray into the product
    Illustration: Slide the tray into the product.
Step two: Define the custom paper size
When defining custom paper sizes, make sure that the width is equal to the measurement of the short edge of the paper and the length is equal to the measurement of the long edge of the paper. For example, if you are creating a custom paper size of 215.9 mm (8.5 in) by 139.7 mm (5.5 in), define the width as 139.7 mm (5.5 in) and length as 215.9 mm (8.5 in).
Follow these steps to define a custom paper size:
  1. On the File menu in the software program, click Print.
  2. Click your product from the Name drop-down list, if it is not already selected.
  3. Click Properties or Preferences.
  4. Click Custom. The Custom Paper Size dialog box opens.
  5. In the Width box, type the width of the custom paper.
  6. In the Length box, type the length of the custom paper.
    Figure : Example of custom paper sizes defined in the Custom Paper Size dialog box
    Graphic: Example of custom paper sizes defined in the Custom Paper Size dialog box.
  7. Click OK.
  8. Click the Finishing tab.
  9. Under Orientation, click Portrait or Landscape.
  10. Click OK, and then click OK again to start the print job.
Cause
The issue can be caused by the following conditions:
  • The custom paper size was not defined correctly in the print driver.
  • The media was not loaded correctly.
