HP Compaq dx2810 Small Form Factor PC - Specifications
Hardware Specifications
Features
Chassis Dimensions (HxWxD)
15.14 x 7.27 x 16.36 inches 385 x 185 x 416 mm.
Temperature
Operating: 50 degree to 95 degree F (10 degree to 35 degree C) at sea level with an altitude de-rating of 1.0 degree C per every 1000 ft (300 m) above sea level to a maximum of 10000 ft (3048 m), no direct sustained sunlight. Maximum rate of change is 50 degree F/Hr (10 degree C/Hr). The upper limit may be limited by the type and number of options installed..
Storage: –22 degree to 140 degree F (–30 degree to 60 degree C).
Humidity
Operating: 10% to 90% relative humidity (Rh), 35 degree C maximum wet bulb temperature, noncondensing.
Storage: 10% to 90% relative humidity (Rh), 35 degree C maximum wet bulb temperature, noncondensing.
Altitude
Operating: 0 to 10,000 feet (0 to 3048 meters) – This value may be limited by the type and number of options installed. Maximum allowable altitude change rate is 1,000 ft/min (304.8 m/min).
Non-Operating: 0 to 30,000 feet (0 to 9,144 meters) – Maximum allowable altitude change rate is 1200 ft/min (365.76 m/min).
System weight
18.4 lb (8.34 kg).
Power
250 W Power Supply – PFC PFC HV immunity (410V/s) with a 115/230v line switch.
Security
  • Padlock loop.
  • Kensington Lock Support.
  • Noble Universal Clamp Lock Cable Kit.
Communications
Features
Communication
Wireless LAN:
  • Realtek 8111C-VB-GR GbE Ethernet Controller.
  • Intel PRO/1000 PT Gigabit PCIe Controller.
  • LSI PCIe x1 56K International SoftModem.
  • HP Wireless 802.11 b/g/n PCIe x1 Card.
NIC: Intel Pro 1000 PT Gb Ethernet PCIe NIC.
Graphics
  • Intel Graphics Media Accelerator X4500HD.
  • ATI Radeon HD 2400XT 256MB Dual Head graphics adapter (PCIe x16).
  • ATI Radeon HD 3450 256MB Single Head PCIe x16 Card.
  • ATI Radeon HD 3470 256MB Single Head graphics adapter (PCIe x16).
  • ATI Radeon HD 3650 512MB Dual Head graphics adapter (PCIe x16).
  • ATI Radeon HD 4650 512MB Dual Head PCIe x16 Card.
  • HP ADD2 SDVO PCIe DVI-D Adapter.
Modem
Audio
Features
Audio
  • Realtek ALC662 High Definition audio codec.
  • 3D audio compliant with AC'97 Rev. 2.3 and HD Audio compatible.
  • Internal PC speaker SFF.
  • HP USB Powered Flat Speakers.
