HP Compaq dc7900 Convertible Minitower PC - Removing and Replacing the Hard Drive
This document is provided to assist in removing and replacing the Hard Drive for the HP Compaq dc7900 Convertible Minitower PC.
Parts required
The replacement part number will vary depending on the Hard Drive that is being replaced. If a part is listed as 'Yes' under 'Requires Return' then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
500 GB, 7200-RPM SATA hard drive, 3.5-inch
504339-001
Yes
320 GB, 7200-RPM SATA hard drive, 3.5-inch
504338-001
Yes
250 GB, 7200-RPM SATA hard drive, 3.5-inch
504337-001
Yes
160 GB SATA hard drive
504336-001
Yes
160 GB, 10000-RPM SATA hard drive, 3.5-inch
439995-001
Yes
80 GB, 10000-RPM SATA hard drive, 2.5-inch with adapter
508311-001
Yes
80 GB, 7200-RPM SATA hard drive, 3.5-inch
449978-001
Yes
80 GB, 7200-RPM SATA hard drive, 2.5-inch with adapter
497728-001
Yes
80 GB, 10000-RPM SATA hard drive. 3.5-inch
439994-001
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the Hard Drive, click on the link below. Or use the product video listing on the HP Services Media Library, then select Hard Drive from the menu on the upper left hand side of the screen.
Click here to view the Hard Drive removal video (right-click on the link to open in a new window/tab).
Hard Drive removal
  2. note:
    This system supports SATA drives only. You do not have to select a cable setting.
  3. Disconnect the data and power cables from the drive.
  4. Pull out on the green drive release latch and slide the drive out of the drive cage.
    If the replacement drive does not include guide screws, remove and reuse the screws from this drive or use the spare screws provided on the drive cage.
Hard Drive replacement
  1. Align the guide screws on the drive with the guide slots in the drive bay.
  2. Push the drive into the bay until it snaps into place.
  3. Connect the power and data cables to the drive.
Parts return
