HP Compaq dc7900 Convertible Minitower PC - Removing and Replacing the Access Panel
This document is provided to assist in removing and replacing the Access Panel for the HP Compaq dc7900 Convertible Minitower PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the Access Panel that is being replaced. If a part is listed as 'Yes' under 'Requires Return' then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Access panel
450713-001
No
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the Access Panel, click on the link below. Or use the product video listing on the HP Services Media Library, then select Access Panel from the menu on the upper left hand side of the screen.
Click here to view the Access Panel removal video (right-click on the link to open in a new window/tab).
  2. Remove the cable lock and/or padlock, if one is installed.
  3. Lift and hold the access panel release latch.
  4. Slide the panel back about an inch.
  5. Lift the panel away from the chassis.
Access Panel replacement
  1. Place the front edge of the access panel over the front chassis guide rail.
  2. Lower the access panel into position on the chassis.
  3. Ensure that the slot in the back of the access panel is aligned with the padlock grommet.
  4. Hold the release latch up and slide the panel forward until it is flush with the front bezel.
