HP gt7720 / gt7725 Thin Clients - Operating and Environmental Specifications
For thin client product QuickSpecs (full product specifications), refer to the HP Product Bulletin and select thin clients.
HP gt7725 Thin Client
Dimensions
Width (front to back)
Height (without stand)
Height (with stand)
Depth
46 mm
254.5 mm
215.18 mm
1.811 in.
10.02 in
8.47 in.
Approximate Weight
1.3 kg
2.9 lb
Temperature Range
Operating**
(max. rate of change is 10° C per hour or 18° F per hour)
Nonoperating
(max. rate of change is 20° C per hour or 36° F per hour)
10° to 35° C
-30° to 60° C
50° to 95° F
-22° to 140° F
*Specifications are at sea level with altitude derating of 1° C/300m (1.8° F/1000ft) to a maximum of 3Km (10,000ft), with no direct, sustained sunlight. Upper limit may be limited by the type and number of options installed.
Relative Humidity (non-condensing)
Operating
(max. wet bulb temperature is 28° C or 84.2° F)
Nonoperating
(max. wet bulb temperature is 38.7° C or 101.6° F)
10–90%
5–95%
10–90%
5–95%
Maximum Altitude (unpressurized)
Operating
(max. allowed rate of change is 457m per minute or 1500 ft per minute)
Nonoperating
3048 m
9144 m
10,000 ft
30,000 ft
Power Supply
Operating Voltage Range
Rated Line Frequency
100–240 VAC
50–60 Hz
100–240 VAC
50–60 Hz
Power Output (maximum)
120 W
120 W
Rated Output Current (maximum)
6.15 A
6.15 A
Output Voltage
+19 V DC
+19 V DC
