HP EliteBook 6930p Notebook PC - Removing and Replacing the Power Button Board
This document is provided to assist in removing and replacing the Power Button Board for the HP EliteBook 6930p Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head P0 screwdriver.
Parts required
The replacement part number will vary depending on the Power Button Board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Power button board - Includes cable.
482964-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Power Button Board, click on the link below. Or use the product video listing on the HP Services Media Library then select Power Button Board from the menu on the upper left hand side of the screen.
Click here to view the Power Button Board removal video (right-click on the link to open in a new window/tab).
  2. Remove the 3 mm P0 Phillips-head screw that secures the power button board to the bottom of the switch cover.
  3. Slide the power button board out from under the two plastic tabs on the switch cover and remove the power button board from the switch cover.
  4. Place the power button board in a static dissipative bag.
Power Button Board replacement
  1. Remove the power button board from the static dissipative bag.
  2. Toe the power button board under the two plastic tabs on the switch cover and lower it into position on the switch cover.
  3. Replace the 3 mm P0 Phillips-head screw that secures the power button board to the bottom of the switch cover.
Parts return
