HP Compaq 6530b Notebook PC - Removing and Replacing the Battery
This document is provided to assist in removing and replacing the battery for the HP Compaq 6530b Notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
6-cell, 55-Wh Li-ion battery
486296-001 (Modified)
No
6-cell, 47-Wh Li-ion battery
486295-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the battery, click on the link below. Or use the product video listing on the HP Services Media Library, then select Battery from the menu on the upper left hand side of the screen.
Click here to view the battery removal video (right-click on the link to open in a new window/tab).
Battery removal
    To reduce the risk of personal injury from hot surfaces, allow the drives and the internal system components to cool before touching them.
  2. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  3. Disconnect all external devices connected to the computer.
  4. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer.
  5. Slide and hold the battery release latch to the release position.
  6. Slide the battery out of the battery bay.
Battery replacement
  1. Slide the battery into the battery bay until it is properly seated and the release latch clicks.
Parts return
