    Fix Windows 10 Update Issues
HP Notebook PCs - Using the Home Screen and Widgets in Mobile Internet Experience
This document pertains to HP Mini models with Mobile Internet Experience
Understanding the Home Screen
The home screen is the first (default) screen you see after login into the system. It is primarily designed to give quick access to E-mail, Browsing, and Multimedia (using icons more commonly referred to as widgets). The home screen also provides quick access to file browser and system settings from its top panel.
From the Home Screen, you can quickly view your photos, play music, browse the Internet, or configure and check your e-mail. You can personalize the Home Screen for quick links to your favorite Web sites, photo albums, music albums, and playlists.
Home screen widgets are meant to be gateways to actual, full-screen applications by providing quick access information functionalities in them. Widgets provide basic functionalities such as “change favorite” available through pop-up menus. At this point, the widgets themselves cannot be changed or replaced with another widget.
Component
Mail
Check and display your e-mails.
Web
Search and browse the Internet and create links to your favorite Web sites.
Music
Listen to your favorite music and create links to your favorite albums and playlists.
Photos
View your photos and create inks to your favorite photo albums.
Program Launcher
Click the Start New Program button to open a new program or to view all of the programs that are installed on your device.
Navigating the Home Screen Using the Widgets
The following features make it easy to access the different areas of the Home Screen.
Component
Click the Mail widget to check for new e-mail.
Click the Program Switcher widget to display the Start New Program button
Click the Home widget to return to the Home Screen
Click the Start New Program button to open the Program Launcher and view all of the programs installed on your device or open a new program.
Click the Help widget to display the system Help and learn about the device.
Use the Mini Player to play/pause, fast-forward, and rewind your music.
The mini player appears only when you play music from the Home Screen.
Click the Logout button to access the power management features such as Suspend, restart, Hibernate, log out, lock the screen, and shutdown.
Click the Settings button to view and customize basic and advanced system settings.
Click the Files button to open the file manager so you can view and manage your files.
Click the Wireless Network widget to open the Wireless Network and create, manage, and use wireless connections.
The Bluetooth widget Indicates that a Bluetooth connection or a Bluetooth device is in the vicinity.
Connection Manager
The Connection Manager is used to check and configure wired and wireless connections (LAN and WLAN).
The System Tray includes the battery indicator, volume control, the time and date.
Program List ,also know as the Launcher. Displays when Start New Program is clicked and lists all programs present in the device. Launcher is divided into six tabs (Internet, Media, Work, Utilities, Play, and ALL) each corresponding to a category of applications as indicated by their names.
