    Looking for Site Help?
HP Photosmart Premium Fax All-in-One Printer Series (C309 and C410) - An 'Alignment failed' Error Message Displays on the All-in-One
Issue
While aligning the printer, the error message 'Alignment failed' displays on the printer control panel. The following issues might also accompany the issue:
  • The printer ejects blank pages
  • A related error message, such as 'Paper mismatch' or 'Paper too narrow', displays on the control panel
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.
Solution one: Make sure that the correct paper is loaded
Follow these steps in the order presented to resolve the issue.
Step one: Load the correct paper
If the tray contains colored, photo, or used paper, the alignment fails.
  1. Remove all the paper from the tray.
  2. Load unused, plain white letter, or A4-sized paper with a brightness level of at least 85 into the tray.
    Look for the brightness level on the paper packaging.
    Figure : Load paper in the tray
    Illustration: Load paper  in the tray
Step two: Align the printer
Use one of the following methods to align the printer.
When the alignment is complete, the printer prints an alignment page and displays a message that indicates the alignment status.
Figure : An example of a good alignment page
Image: An example of a good alignment page
  • If your alignment page looks like the example, you do not need to continue troubleshooting.
  • If your alignment page does not look like the example, continue to the next solution.
Solution two: Check the cartridges
Follow these steps in the order given to make sure that the cartridges operate correctly.
Step one: Check the ink levels
Empty or nearly empty cartridges can cause alignment failures. Follow these steps in the order presented to check the ink levels in the cartridges.
Use one of the following methods to check ink levels in the cartridges.
If the printer has a refilled or remanufactured cartridge, or a cartridge previously used in another printer, the ink level indicators display inaccurate or missing information.
Step two: Remove and reinstall the cartridges
One or more of the cartridges might not have full electrical contact with the printer. Removing and reinstalling the cartridges might help.
Important: Before you begin, make sure that the cartridges are compatible with your printer.
Visit HP SureSupply to check ink or toner cartridge compatibility or purchase replacement cartridges and other supplies.
  1. If necessary, select your country/region.
    Figure : Country/region selector
    Selecting your country/region
  2. Follow the on-screen instructions to order new supplies or check cartridge compatibility with your printer.
You can also purchase genuine HP cartridges and supplies from other retailers.
  1. Press the Power button () to turn on the printer.
  2. Grasp the access handles on the sides of the printer to open the cartridge door. The carriage moves to the center of the printer.
    Figure : Open the cartridge door
    Illustration: Open the cartridge  door.
  3. Wait until the carriage is idle and silent.
  4. Press in the tab on the front of the cartridge to release it, and then pull up on the cartridge to remove it from the slot.
    Figure : Remove the cartridge from the slot
    Image: Remove the cartridge from the slot
  5. Reinstall the cartridges with the contacts facing down, and then slide the cartridge into its slot.
  6. Press down on the cartridge until it clicks into place.
    Figure : Insert the cartridge
    Image: Insert the cartridge
  7. Close the cartridge access door.
    Figure : Close the cartridge access door
    Image: Close the cartridge access door
  8. Press the Power button () to turn on the printer if it does not turn on automatically.
Step four: Clean the printhead
Follow these steps to clean the printhead from the printer control panel.
  1. If the error message remains on the control panel display, press the OK button to clear it.
  2. Press the Setup button () on the printer control panel.
  3. Press the Down Arrow button () to select Tools, and then press the OK button.
  4. Press the Down Arrow button () to select Clean Printhead, and then press the OK button.
The printer cleans the printhead and prints a test page.
  • If these steps resolved the issue, you do not need to continue troubleshooting.
  • If the issue persists, continue to the next solution.
Solution three: Reset the printer
A power reset drains power from the printer and returns the printer to the same settings after restarting. To eliminate any potential power deficiencies that might prevent a successful alignment, move the printer to another location and plug it directly into a wall outlet. Follow these steps to reset your printer.
  1. Press the Power button () to turn on the product.
  2. With the product turned on, disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Wait at least 15 seconds.
  5. Plug the power cord back into the wall outlet.
  6. Reconnect the power cord to the rear of the product.
  7. If the product does not turn on by itself, press the Power button () to turn it on.
Contacting HP for service in all countries/regions except Asia Pacific.
If you completed all the preceding steps and your product still has an issue, service the product.
Check your product warranty to determine if your product is still under warranty, and then go to Contact HP Support to schedule a repair or replacement.
Country: Flag Serbia
